I replace cord on saw but lost which wires go where cause something keeps shorting it out.
The green wire is the ground and connects to the rounded pin on the plug. The red wire connects to the 120V power and the black (or white) wire is the neutral. If you have no red wire it is whatever is left after the black (or white) and green are connected. The neutral and the black may connect to the same place in the tool but the purpose of the ground is to keep you from being shocked if the 120V connection inadvertently touches the case of the tool. In the tool make sure the green is connected to the case of the tool,
SOURCE: REPLACING POWER CORD
White to center, red on Right, Black on left, Green goes to case or external ground screw.
SOURCE: My tomtom 920 keeps acting like it is shorting out.
If its still under warranty, get it repaired.. it sounds like hardware problem. Of course, you'll need to contact TT for repair options.
SOURCE: four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
SOURCE: what causes plark plugs to foul,they keep turning
Plugs foul for a couple reasons, engine in poor condition (worn rings - poor compression), wrong oil, wrong plugs, bad riding conditions, cheap fuel, out of tune, carb out of tune.
You are not mixing your fuel with oil are you?
You might need a carb tune up (Id start by adding some injector cleaner to the fuel according to the bottle instructions.
You might put a hotter plug in your engine, one or two range increase.
If you will go to a good auto parts store, they will probably have a chart of assorted plug conditions and their cause. The counter man may be able to make a recommendation to you.
SOURCE: i need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
