SOURCE: whirlpool duet dryer - PF error
Here are 2 good ones from very large inventory companies
http://www.apdepot.com/index.asp
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
SOURCE: Whirlpool dryer will not start, replaced the
Sounds like you have a dead short to ground. Check the power cable & look for any rubbed through insulation & make sure the ground is still attached to it's post.
SOURCE: whirlpool dryer wont start
hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
SOURCE: On a SE1000 maytag laundrystack
Here is a link to all the parts for that unit. The control board cost is over $200.00 and you may be better off getting a new setup. Let me know if you want to try and fix this unit and I will help you thru it.
Also, here is a link to my service manual for that unit. This will help you quite a bit!
Regards,
Richard
