Question about Kohler Electrical Supplies
Kohler generator 5E run but not well, keep shutting off
Drain the fuel bowel and line, run for 2 3 min. and shut off each time but restart. I checked the impeller good, pumping water out the discharge, oil level is good only has 74 hrs worked fine last season until I had the impeller issue and I also replace the drive sheeve.
  • Kohler Master
  • 986 Answers
Http://www.kohlerpower.com/onlinecatalog/pdf/g2058.pdf
Safety shutdowns:
  1. Loss of coolant
  2. High water temperature
  3. Low oil pressure
Likely one of these. If no indicators at a panel check at the connector.
Posted on Feb 18, 2019
  • Carl Rock
    Carl Rock Feb 19, 2019
    Ooops, I didn't account for "worked fine last season". Suggest you take a fuel sample and check for water. I don't believe that's you problem unless you have to drain fuel bowl every time it shuts down.
    I expect you'll find a faulty sense circuit effecting an unwarranted shutdown. That or a fault indicator is failing to light and shutdown is warranted.
    Sergeant:
  • 279 Answers
Sounds like the main fuel circuit in the carburetor is clogged. Clean the fuel system.
Posted on Feb 19, 2019
  • William Nichols Feb 19, 2019
    sounds like the main fuel circuit in the carburetor is clogged. Clean the fuel system.
SOURCE:
  • 5603 Answers
SOURCE: Gen runs for 8 min then shuts down most of the
Check for intermittent oil pressure switch. Monitor the possibility of low oil pressure shutdown.
Posted on Mar 23, 2010
  • 5603 Answers
Is oil pressure good? Check it when it shuts down.
Most of these have a switch that kills it if pressure drops. At operating temp the pressure may drop.
Posted on May 09, 2010
  • 224 Answers
SOURCE: 70 thermstat controled
Well this one is trying to detect flame, please try checking the fire eye clean the lens with windex and a terry cloth rag and try to fire it up. Make sure that this eye has an unobstructed view to the flame, not a correct thing to do but jump the eye out and see if you run longer if so replace the fire eye.
Posted on Dec 14, 2010
heatman101
  • 43501 Answers
SOURCE: Kohler 5E, initially water pump
You did not say what fuel you running the motor on??? It sounds like it may be LPG or Propane.... is so then it seems as though you do not have enough surface for evaporation...
heatman101
Posted on Jun 15, 2011
alice3
  • 5 Answers
SOURCE: Low fuel pressure 99 cherokee classic
either fuel pump but change fuel filter first and see if it helps
Posted on May 13, 2012
My kohler 5750009 generator will run perfect for about 2 hours then shuts off. It will restart. What should I check?
See if there is a heat shield for spark plug. Make sure proper plug is installed and gapped.
May 19, 2015 | Kohler Electrical Supplies
Why does my Kohler 7.3 generator start and runs great for about 5 min. then shuts downRestarts fine but shuts down seconds later. Upon removing rad cap, fluid is seen moving upon warm up. How do I...
change the oil to the correct specification first. As the engine runs the heat changes the viscosity and overheats or trips the oil alert switch. If its over 10 years old change the oil alet magnetic switch
Jun 12, 2014 | Kohler Electrical Supplies
My kohler 4ckm21 generator starts great but will run for 8 min. and shut down ?
If it runs that long, you may have a bad oil pressure switch, loose connection, or fuel pump. You didn't indicate whether the time was under laod or not
Aug 07, 2013 | Kohler Electrical Supplies
I HAVE A GAS OPERATED PRESSURE WASHER IT WILL RUN A WHILE THEN SHUT OFF AFTER SITTING FOR ABOUT TEN MINS IT WILL START AT THAT TIME IT MIGHT RUN FOR A FEW MIN MORE AND THEN START SPUTTERING AND SHUT DOWN...
Definatley a fuel / carb problem . remove carb-remove fuel bowel turn carb upside down float should be level to carb body if not replace needle and seat. drain fuel from tank into a clear container to see if there is water in fuel (water will settle to bottom of container ) also check jet in middle of carb to see if plugged.
Dec 27, 2017 | Campbell Hausfeld PW2102 Gas Pressure...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Kohler 5E, initially water pump impeller no good causing overheat and shut down of motor (overheat switch killed ignition), replaced raw water pump impeller, heat exchanger stays cool, exhaust manifold...
heatman101
Jun 13, 2011 | Kohler Electrical Supplies
Honda eg3500x starts up fine but will only run choked.
SHUT OFF FUEL SUPPLY AND KEEP VAPORS AWAY FROM IGNITION SOURCE pull the float bowel off carb and REMOVE then clean the orifice in the main jet with a piece of stranded wire or shut off gas and drain the float bowel close drain screw if equipped then get some yamaha carb cleaner and follow directions MAIN JET ORIFICE IS PLUGGED. GOOD LUCK JOE
Feb 01, 2011 | Honda Electrical Supplies
Gas is leaking out when the generators is running. What should I do to fix it?
where the -tank, lines ,fuel ****? , o ring between carb body and bowel? is it running ok? if not and fuel is coming out of carb than your float and needle is stuck by gummy deposits. you will have to remove float bowel and gently pull down on float ,a good carb cleaning is in order ,might as well check main jet and others for blockage.SHUT OFF FUEL AND KEEP FUEL VAPORS AWAY FROM IGNITION SOURCES do not run it if you have a leak.
Feb 01, 2011 | Electrical Supplies
Starts, runs a few seconds then shuts down. Will restart immediately, but then shuts down again. 32.5 KW, White diesel eng.
Check for a low lube oil sensor problem first. Could be low oil pressure or a failed sensor. The sensor is timed and if pressure doesn't come up, then unit is shutdown.
Check fuel filter and also air leaks in the fuel supply lines.
Check if the fuel shutoff solenoid is responsible for the shutdown. If it closes just before the engine quits, then it is being commanded to shutdown, probably as a safety interlock.
Oct 11, 2009 | Kohler Electrical Supplies
Electrical Supplies Logo
47 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
