Whole cabinet has to come off. Then insert missing screws through cabinet into top. YouTube video will be helpful in removing cabinet b
Perfect answer! I had seen the wrong video for what I believe was a new washer model. Thank you so much for saving me money. Turns out that it probably wasn't the previous repairman's fault. I think that the screws that held the top of the cabinet together probably just worked loose and fell out. All is well now, thanks for saving me time and money!
SOURCE: RE: Putting whirlpool washer back together
ok I know this is a problem heel i had trouble doing y first few but i learned a trick 1. make sure your front feet are off the ground at least 1/2 inch if they are rusted or broken place a screwdriver under the black rails. ok 2. wirh the cab. in front of you open the lid andhold it under that lip tilt it forward and then slide it toward the unit look down the lid hole you want the front edge to line up first as you slide it down there are two flat pins sticking up on both sides about 7" back fron the front corners these must fit into the cabniet you then drop it down slowly put the left clip on first then place you hand down the back right side pull it forward and install your other clip one note the fill dispenser will need to get under the cabniet before it will seat properly. connect your lid sw and close the console. let me know if this works and please rate this help
Thanks Gary
I would agree with you, it sounds like it isn't going back together correctly. When I put the cabinets back on them, I first make sure all 4 of the spades sticking up from the base are straight and not bent over. Next I grasp the hole the lid covers towards the front and lift and pull it towards me so the bottom of the cabinet is closer to me than the top. Next, I use my foot to push the bottom of the cabinet under the bar that goes across the base of the machine. Then I tilt the top of the washer back towards the machine. I wiggle the sides, until the cabinet seats into the spades coming from the base. After it seats properly, the clips should be lined up properly to be installed.
SOURCE: Evenflo Infant Car Seat Canopy Fastener
There Should be a 1 800 number on the Box That you can call
and they should send the peice your missing
if not try going in to a store Where they sell simlaler Products
and see if they carry the peice your missing
I hope I have been of use
SOURCE: can't adjust 2004 Ford Expedition headlight
I had a similar problem on my 04 expedition. I just bought it and the headlights were aiming too far down. A rather larger gap was noticeable between the headlight and the hood. The so called adjustment bolt did nothing. I removed the headlights and found 2 issues. On the adjustment bolt there is a washer. Make sure when you re-install the headlight the washer sets on top of the plastic slot and is visible when looking down behind the headlight. Without the washer being in the correct location it will not tighten the headlight in place.
Second I found the adjustment bolt adjusted nothing. It merely tightened the headlight in place. What I had to do was to loosen this bolt and physically move the headlight into place and the re-tighten the bolt. Hence the slot is the adjustment. Turning the bolt CW or CCW did not move the headlight.
I tried several things trying to figure why the lights would not move until I realized I could move the light with my hands and tightened them in place using the adjustment bolt.
This may not be your issue but I found the owners manual instructions to be useless.
SOURCE: Need Diagram of How to Reassemble Agitator or Whirlpool Top Loan
LXR9245EQ1
Thanks for giving the correct model number.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=257320
Click on the diagrams in the left-hand side. You can print them out also. They will show how the unit is assembled.
Take a look at this tip I wrote on the no agitate or spin condition of your washer.
I just found the model number it's lsq9659lw1
