My Karbon safe has locked because wrong password entered three times.How do I unlock it
If your Karbon safe has locked due to entering the wrong password three times, you will need to follow the manufacturer's instructions for unlocking it. Here are the general steps you can take:
Wait for a period of time: Karbon safes typically have a security feature that locks the safe for a certain period of time after three incorrect password attempts. Wait for the period of time specified in the instructions before attempting to unlock it again.
Use the backup key: Many Karbon safes come with a backup key that can be used to unlock the safe. Locate the key and use it to open the safe.
Contact the manufacturer: If you cannot unlock the safe using the backup key or you do not have a backup key, you can contact the manufacturer for assistance. They may be able to provide you with a master override code or other instructions for unlocking the safe.
It is important to note that attempting to force the safe open or tampering with it in any way could cause permanent damage to the safe and void any warranty or insurance coverage. Always follow the manufacturer's instructions and contact them if you need assistance.
The key is the over ride to open it. If it is a dial combination, turn the key to unlock, then turn the dial to withdraw the bolts. IIRC, the last turn on a combination safe is clockwise. But according to page 2, if you only use the key, it means you are keeping the dial at it last position. From what is says, you now need to open it again using the combination that was given to you. https://firstalert.my.salesforce.com/sfc/p/#o0000000bgz6/a/3l000000XrEk/q9_eBXnzfEFRbQEkPgJge9p9WPx.DFjuECqJ70zwArc
Turn on and use safe mode Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
Turn the device off. Press and hold the Power key. When Samsung appears on the screen, release the Power key. Immediately after releasing the Power key, press and hold the Volume down key. Continue to hold the Volume down key until the device finishes restarting. Release the Volume down key when you see Safe Mode on the device. Uninstall apps that are causing a problem.
Turn off safe mode Press and hold the Power key. Tap Restart. The devices restarts in normal mode.
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Trunki has secure locks that keep your child's favorite items safe
inside for the ride. Simply slide the lock down to close and use the
keys located on the ends of the shoulder strap to lock it in place.
Unlock and lift the locks to open the suitcase again.
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi radio from the car manufacturer! The sequence of programming is: 1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed. 2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt. 3. By the #1 key you will set up the first safe code digit. 4. By the #2 key you will set up the second safe code digit. 5. By the #3 key you will set up the third safe code digit. 6. By the #4 key you will set up the four-th safe code digit. 7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
