Question about HP LaserJet 1010 Printer
Hp 1010 laserjet all light on
When i on the printer it take the command and print but when i give second command all three light on
  • HP Master
  • 8,829 Answers
Printerguy
  • 31 Answers
SOURCE: HP LaserJet 2420dn prints twice
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Posted on Aug 24, 2007
  • 18 Answers
SOURCE: Printing problem in hP laserjet 1020
just inspect your printer's front cover.there r two plastic stick which is attached with the printer cover.this two stick hit the two particular point.
1.power switch conector(left side corner)
2. scanner sensor conector(right side middle)
i think your left side stick may be broke try it.
Posted on Feb 20, 2008
wayneard
  • 1901 Answers
SOURCE: 300 dpi priting
Your printer doesn't have a 300 DPI setting, however, you can select "EconoMode" from the "Preferences" menu after you select "Print". Look for a tab that says "Quality". EconoMode will be lighter than normal 600 DPI printing, thereby saving toner.
Posted on Nov 13, 2008
SOURCE: laserjet 1010
Hp 1010 printer driver downlod free
Posted on Nov 27, 2008
steveparlin
  • 61 Answers
SOURCE: Printing problem with HP laserjet 1320
I've seen this error on this model in the past. I was only able to resolve the issue by replacing the formatter board. Hope this helps.
Posted on Aug 31, 2009
All the lights are on in hp laserjet 1010 printer i cannot print any page how to solve this problem
Try a hard reset of printer and/or reinstall the software, Check cartridges for ink and operation.
Sep 04, 2016 | HP LaserJet 1010 Printer
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
My hp laserjet 1010 printer is not printing..just printed the other day and then the next day it didnt print. all the lights (2 yellow lights and 1 red light) are lighted.. hope you could help me.. more...
sometime, it is very silly but true, we forget to check the connectivity of the printer to computer. Plz check unplugin and plug in back the cable attched to printer and computer. Then restarting both computer and printer. If that does not solve, then uninstall and reinstall the printer software.
Jun 08, 2011 | HP LaserJet 1010 Printer
It does not print
my printer hp 1010 was printing fine and suddenly stop print pages.it take in page and through it out as blank page.
Jul 02, 2009 | HP LaserJet 1010 Printer
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
My have hp lase printer 1010 driver
im kosova drvers hp laserjet 1010 pleas
Feb 17, 2009 | HP LaserJet 1010 Printer
Trouble Shoot for Printing HP Printer
the problem is with the sleeve that inside the fuzer unit.
it may shredded.. you cant solve the problem by your self.
thanks
Feb 22, 2008 | HP LaserJet 1020 Printer
Paper is getting twisting during printer
If it prints but comes out curly then
Paper is damp, try fresh paper.
Aug 16, 2007 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
26 people viewed this question
Clive
Clive
