SOURCE: lc320em8 emerson 32 remote code problem
did you try the ge codes its the same brand sometimes that works
SOURCE: rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
SOURCE: need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
SOURCE: I have a phillips universal remote and need the
There are lots of codes....hopefully this helps:
http://www.universal-remote.net/philipsmagnavox.html
SOURCE: What is the 4- digit code for a emerson tv when
Please go to this website and select your region.
http://www.urc.philips.com/
Then shows the remote models selct the model which you have, then it opens the page you have both tree and four digit codes for TV/VCR/DVD in pdf format.
Click on it and you can get the code for your TV.
Thanx
