Question about Sanyo Televison & Video
I tried a new antenna on my Sanyo tv model #DP42840 and it did not work I have attached my old antenna back but now can only get 3 channels instead of my 28 or 30 channels
    Top Expert:
  • Sanyo Master
  • 50,983 Answers
You may have to repeat channel searching to get back to normal.
Posted on Feb 18, 2019
techman
  • 3130 Answers
SOURCE: How to UNDO autoset (channel setter)?
If I am not mistaking this is the same set as the panasonic PV-c2020. I attached an owners manual link here this should help you. Good Luck. http://service.us.panasonic.com/OPERMANPDF/PVC2020.pdf
Posted on Mar 17, 2007
  • 556 Answers
SOURCE: No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Posted on Oct 06, 2007
SOURCE: sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Posted on Sep 15, 2008
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 13, 2009
SOURCE: Hook up old tv antenna to converter box
how can i connect inside anntena to the tv and converter box?
Posted on Oct 16, 2009
How do I hook up an indoor antenna to my Sanyo TV
There is a threaded connector marked cable/antenna. You use this connection to attach the antenna cable. Then you do a channel scan with the tuner set to antenna not cable.
Nov 21, 2016 | Sanyo Televison & Video
Is there a antenna somewhere in my sanyo smart t v?
There will not be an antenna that can receive TV signals internal to the set. Some sets may have a Wireless Internet antenna installed since some models can act a as wifi hotspot. If you need to access local TV channels, you will need to get an external antenna and attach it to the set.
Sep 19, 2015 | Sanyo Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
After setting up my new TV and running the auto channel search, I was only able to pick up channel's 9.1, 9.2, 9.3, & 11.1, 11.2, 11.3. The old TV (using the same antenna) was able to pick up the 3's,...
I guess it depends on where you put the antenna for the old tv and the new. If the antenna is in the same place then it follows the rule that not every tv set receives and displays the same. This being said means that your going to have to change direction of antenna to compensate for for the lack of reception on new set. Rember the new digital is line of sight transmission. Not all the towers are in the same place. Try adjusting antenna or get antenna booster.
Oct 22, 2010 | Sanyo Televison & Video
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
