Check that the load is within the 6kg limit and not entangled into a ball, which will unbalance the drum. Separate the items and try again. I believe Bosch has a telephone help line.
Nov 10, 2012 - bleed screw, jeep liberty limited, 2002, 3.7 L, no heat - Jeep Cars & Trucks question. ... Open Question ... Feel radiator and heater hoses, should be very warm to touch,if hoses ... Where is the location of the slave cylinder in a Jeep Liberty2005 ... Bleeding air out of a 2003 jeep liberty sport with a 3.7 motor.
? 7:17
https://www.youtube.com/watch?v=Nv0HpH2ymB4
Jan 24, 2014 - Uploaded by 1A Auto Parts
http://www.1aauto.com/1A/ThermostatHousingRel/Jeep/Liberty/ ... What no engine heater install 2007 3.8 j wrangler video ....When opening up the bleeder valve, do you just keep it crackedopen until you have no air bubbles ... already replacing the water pump at 138,000 on an '05 Liberty Limited 3.7L..
You can tow just about anything with anything if you have the right gearing. BUT, Your limit is set by the kind of hitch (class rating) you are going to use. I use a simple rule of not towing anything more than double the weight of the vehicle you are pulling with. In towing heavy loads you will need an electric trailer braking system, stabilizer bars, lighting harness addition (applies overall...some require an add on module additional to wiring to prevent system damage), heavy duty radiator and an external transmission cooler. (also, more frequent trans fluid changes, best to use synthetics) If you will be towing on a regular basis, I'd also look into getting the "police package" in regards to sway bars and shocks (all around) as it helps with control.
REMOVE MASTER SWITCH UNPLUG IT 12V TEST LIGHT YOU SHOULD HAVE TWO HOT WIRES . IF THERES POWER THE PROBLEM IS IN THE WIRING HARNESS FROM THE DOOR TO THE THE VEHICLE. THE WIRES TEND TO BREAK AT THIS POINT. YOU DID CHECK FUSES AND WINDOW RELAY
