Question about RC Toys
My rc hyper active air hog wont charge can anyone help. the light just flashes red then turns green in just 3 seconds and then wont charge.
SOURCE:
mellomania
  • 121 Answers
SOURCE: Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Posted on Nov 13, 2007
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
BillB-SA
  • 2761 Answers
SOURCE: camera wont charge. green light comes on for a
This normally indicates a battery problem. Remove the battery and wipe the contacts (battery and camera) firmly with a dry cloth to remove any corrosion that may have built up on them. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, remove any debris that may have fallen into the battery compartment, then insert the battery and connect the camera to the charger. If the green light stays on, the problem is gone and you can charge the battery for several hours and then use the camera. If the red light comes on, it's likely time to replace the battery - especially if it's more than a year old.
HINT: Always remove the battery if you don't plan to use the camera for a week or more. This will prevent corrosion buildup and extend both battery life and camera life.
Bill B
Posted on Apr 25, 2010
  • 4 Answers
SOURCE: when charging the red light flashes for ten
If green flashes you will need to change batteries.
Posted on Jul 17, 2010
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
Hyperactive air hogs rc car keeps going doesnt stop how do i fix it?
I had that problem to but I fixed it. I'm not sure if it would work because I don't have a airhogs hyper active I have a air hogs hyper active 5. So to fix it there should be a dial next to the tire on the remote so you have to put thatdial thing in the middle
Aug 17, 2012 | Toys
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
My air hogs switchblade's controler keeps turning off while its charging whats wrong?
always turn the switch blade off when charging it or it wont charge it and the red light goes off to save batteries on the controller..when done right it flashes red..only when it's flashing red and green will it be charged
Dec 31, 2010 | Master Heaters Air Hogs Switchblade Black...
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Toys Logo
50 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
