Russell Neumeier Posted on Feb 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I hook my Teac EQA-20 equalizer to a PA mixing board? If so how do I do it?
Franco Dosil
Level 3:
Top Expert:
  • Teac Master 10,542 Answers
  • Posted on Apr 15, 2019
Franco Dosil
Teac Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377285
Points
178965
Hello Russell, if you can connect your Teac equalizer to a PA table, depending on the type of table, you have to connect it between the output of the table and the input of the amplifier, you would have to adapt the consolan output connectors to the RCA's input and the RCA output of the equalizer to the type of connectors that the amplifier has
You can also connect it, if the console brings the Insert tab in the line output and there you will use a stereo plug connector, you will have to see which connection brings the insert
Hola Russell, si puedes conectar tu ecualizador Teac a una mesa de PA, dependiendo del tipo de mesa, lo tienes que conectar entre la salida de la mesa y la entrada del amplificador, tendrias que adaptar los conectores de salida de consolan a los RCA de entrada y los RCA de salida del ecualizador al tipo de conectores que tenga el amplificador
Tambien lo puedes conectar, si la consola trae la ficha Insert en la salida de linea y ahi utilizaras un conector plug estereo, tendras que ver que conexionado trae el insert
3 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jul 30, 2009
SOURCE: manual
amp output goes to eq input
eq output goes to amp input
WHEN USING TAPE MONITOR on amp you run record from amp to input on eq and
output from eq to play on amp
Anonymous
  • 682 Answers
  • Posted on Dec 07, 2009
SOURCE: trying to hook up a teac eqa-20 equalizer to a
record out---------equalizer in ----------equalizer out----------tape in.
Anonymous
  • 8546 Answers
  • Posted on Sep 11, 2011
SOURCE: I have a Kenwood VR-507
As with any stereo analog device, processor or tape deck - Outs go to Ins. But any typical AVR will only be able to use it for analog stereo sources. Once a Tape Loop is engaged all digital inputs are disabled though you CAN still use DSP effects on the analog sources.
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
I have a Kenwood VR-507 trying to hook up Teac EQA-120 Home Equalizer
1helpful
Hookingup equilizer to tape deck i dont know i am trying to help my neighbor but of coarse he not home at the moment can i get get back to ya later tonight thankyou todd [email protected] or...
OUTs to INs. Record is IN, Playback is OUT.
Be advised that any analog sound processor on a multichannel AV will ONLY work on analog sources and activation of the Tape Loop will disable digital sources.
SECURE line? Nothing is secure anymore.
1helpful
I have a teac receiver AG-790 and would like to hook an equalizer to it. How do i go about it?
Find the manual at:
http://www.teac.com/consumer_electronics/receivers_&_tuners/ag-790a/
and on page 6 they show how a Tape Deck is attached. Attach the EQ exactly like that and if you have a Tape Deck or two attach IT(them) to the EQ as if IT was the receiver.
To engage the EQ at the receiver choose Tape and everything passing through the receiver wil lbe routed OUT to the EQ and back IN via the PLAY connections.
3helpful
Trying to hook up a teac eqa-20 equalizer to a sansui 881 receiver
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
The grapic display lights but there is no output
1-check your input and output cable.
2-check all your control volume and slider in proper setting.
3-confirm that input sound source is working properly.(try it without the equalizer).
4-if the cables are o.k and sound source is o.k and you still get no output you must pass it to service center.
1helpful
Manual
1helpful
Need to wire a teac eqa20 to a sony reciever
record out from receiver to equalizer in equalizer out to tape in
Yamaha 5.1 receiverhookup to teac equalizer
record output from receiver to linein of eq,and line out from EQ to PLAYBACK of receiver Thank you very much albie 20
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
