Did all the Google tips - still nothing. Unplugged for 10 minutes, nothing. Tried the factory reboot, nothing. Seems like there is no power.
SOURCE: Tv won't turn on
Most likly it is a problem in the power supply regulator circuit. pretty common for Toshiba TV sets. If you know about TV serviceing, first thing to replace would be the regulator IC as that is the problem 80% of the time. if that does not help then you will need a schematic to trace out the regulator circuit. Good Luck PS please dont forget to rate this thread.
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
SOURCE: DVR keeps restarting / rebooting
Jay .. if you still have the receiver. heres what you do. reset the receiver and when the blue screen comes up saying "Hello your directv receiver is starting up" On your remote type in 0 2 4 6 8 .. then it should go to a screen saying "new software found" . Let it download the update.. That should fix the issue .. However if it doesn't then it could be the hard drive. The pcb board on them usually fries.. but that can be ordered too... let me know how this works... you can email me at [email protected]
