SOURCE: Parking Brake light and beeping is on when parking brake is disengaged
this could also result from low brake fluid check the brake level if it is full un plug the switch @ the e-brake lever and see if it goes out if it dose the switch needs replaced
SOURCE: bmw 5series 2001 not changing gears, only drive and neutral
hi nickie, it sound like possibly the shifter unit is broken or the shift cable is damaged. it is also possible that some loose change could have wedged itself in the shifter unit. most dealers charge 1hr to access the shifter to inspect and check the cable.
SOURCE: s class stuck in park
Try this. Start engine, pump brake pedal four times, depress brake pedal and try selector again.
SOURCE: hyundai excel 1996 automatic will engage reverse
It appears you have a Forward Clutch FAILURE. Replace the trans after you get it diagnosed and verified by a professional technician. By the way, do you have a Check Engine light? If so, what is the diagnostic code? The dealership can scan the system and find any codes which may have been stored in the TCM (Transmission Control Module). If there were any 'Incorrect Gear Ratio" codes, it's most probably the trans itself.
SOURCE: The transmission shifter is loose on my 1993 Ford
sounds like an obstrution in the linkage look at the lever on the trans also check the cable to see if it is freyed
I want to help you with your question, but I need more information from you. Can you please fwd details to [email protected]
