SOURCE: Laser issue
sounds like the mirror actuator is broken.... (this is a small motor which moves the mirror on the laser assembly.) The laser unit needs replacing. however the unit is modular, so can be replaced easily. if this is under warranty you could return it to the manuf... if not, if you can order a laser unit you can replace it yourself.
SOURCE: The red beam on my laser won't show outdoors?
Check for a lint ball or a small piece of debris in the lens area. The smallest piece of anything will knock the brightness down. New batteries would be the only other thing I would think of.
