There is a huge buildup of lint and I can't get at it
SOURCE: how to remove lower front panel/amana gas dryer model ndg2330aww
look under the fornt panel 2 5/16 screws holding it on
SOURCE: bOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
This is a two person job. The spring part of the metal ring goes at the 6:00 position (note the groove on the metal part of the machine). Fit the ring into the gasket as much as you can on the hinge side. While one person uses pliers to stretch the spring, another person uses a flat head screwdriver to move the ring into the gasket groove. The trick is to stretch the spring as straight and close to the machine as you can or else the ring pops off and the gasket has to be reset.
SOURCE: Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
SOURCE: how to remove lower front panel on kenmore 90
On my 7 year old Series 90 Dryer, I
- unplug the dryer
- use a flash light to locate the two black metal spring clips (located about 3 inches from each end of the lower panel along its top edge). They can be seen in the crack between the upper and lower panels.
- use a putty knife, or similar tool, to press down each clip while pulling out that edge of the panel.
- The panel slips off the lower clips easily.
- on some models there is a lone yellow wire with a connector on the end. If it is unconnected to anything, don't go nuts thinking that you have disconnected a wire by accident. Its one of those unused wires on some models.
- collect as many coins as possible before you vacuum the inside of the machine. Leaning the machine forward can often slide hidden coins to the front. BE SURE YOU CAN LEAN THE MACHINE WITHOUT HAVING IT FALL ON YOU. Otherwise, plan on collecting the coins from the vacuum cleaner when you finish.
- replace the panel by first threading the panel on to the lower clips, then closing the panel. CLICK, CLICK. FINISHED.
Congrats you have cleaned it, possibly avoided a house fire and added to the mad money collection. Hope this helped.
A code E27 means a problem with the door lock. Try
unpluging the machine for an hour and see if it resets the lock. If not remove the cover on the lower right
corner you will see a white plastic pull cord. Pull the cord and pull open the
door. If that doesn't reset the door lock you will need to replace the lock.
