Tablets & eReaders Logo
A
Anonymous Posted on Feb 17, 2019
Ask id namba ipad modele 1460 - iPad Apple Tablets & eReaders
Carlos L. Glez
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Apple Master 419 Answers
  • Posted on May 23, 2019
Carlos L. Glez
Apple Master
Level 3:
Loyalty:
Answers
419
Questions
Helped
79928
Points
1953
Hello, I think you mean the IMEI number to unlock an Ipad, I leave a link and a video with possible solutions.
Note: Please note that using the option of the video is your responsibility for any damage that may occur.
Find the serial number and other information for your iPhone iPad and iPod...
Apple ID and password help. My deceased husband set up the password and ID and I am locked out of my IPad. It asked for the original
Try hooking your iPad up to iTunes on your computer and perform a factory reset, changing the username and password.
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
I took my ipad to be restored everything was cleared off. I need an ID and a password what do i do?
was it restored to factory and asking as if new set up if so use your apple id/password as before ==if this is not a new/default set up call who ever did the restore about the password and id request --if you dont have an id or password can start one as a new account ---
1helpful
DMPKJTW7F182
it is an Ipad 4th generation (WiFi only)
Lookup Mac Specs By Serial Number Order Model EMC Number Model ID EveryMac...
iPad 4th Gen (Wi-Fi Only) 1.4 GHz* Apple A6X apple-ipad-3rd-gen.jpg Intro Date: October 23, 2012* Disc Date: October 16, 2014** Order No: MD510LL/A* Model No: A1458 (EMC 2604*) Subfamily: iPad 4th Gen (Wi-Fi) Model ID: iPad3,4 Std RAM: 1 GB* Std VRAM: None Std Storage: 16, 32, 64, 128 GB* Std Optical: None Complete iPad 4th Gen (Wi-Fi Only) Specs
How do i unlock forgot apple id password/icloud for a
The Apple ID is different from the iPad password, and is handled through iCloud. You may want to pursue this in Apple's help web site:
http://help.apple.com/icloud/#/mmfc0f1a3b
Lookup serial numbers
it is an iPad 2 (WiFi only)
iPad 2 (Wi-Fi Only) 1.0 GHz Apple A5 apple-ipad-2.jpg Intro Date: March 2, 2011* Disc Date: March 18, 2014** Order No: MC769LL/A* Model No: A1395 (EMC 2415) Subfamily: iPad 2 Model ID: iPad2,1 Std RAM: 512 MB* Std VRAM: None Std Storage: 16, 32, 64 GB Std Optical: None Complete iPad 2 (Wi-Fi Only) Specs
lookup-serial-numbers-z4tjgmdaalvpp2apynga12w3-2-0.jpg lookup-serial-numbers-z4tjgmdaalvpp2apynga12w3-2-2.jpg
iPad vs iPad 2 vs iPad 3
My ipad is displaying a picture of a person behind bars as if in jail how do i unlock it from this screen? N
If it is your iPad, you must know the unlock code. and the password connected to your Apple id. If you entered three times a wrong code, the iPad locks up and only can be unlocked when you enter your password, belonging to the Apple account the iPad is connected to.
This security is so strong it is not hacked. The legal owner still can send messages to it. Perhaps he /she did send the picture?
If the iPad is really yours and you have the invoice, take both and your ID, to an Apple store and ask if they can help.
On my apple ipad mini model A1432 that I bought from a friend the passcode that I'm putting in is incorrect. How can I get a new passcode?
After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what is only a part shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. Just go back to your friend, ask him to unlock the screen, to wipe the content and reset the iPad to factory settings.
For that goto settings, general and scroll to the bottom line and press that. then the second line wipe everything. Again the login code is asked. but after that the iPad is empty.Your friend should also remove the iPad from his list of registered Apple equipment.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
