Question about HTC Touch P3450 Smartphone
How to install window in HTC dopod D810 - HTC Touch P3450 Smartphone
I want to change the language of my CHT Dopod D810 since it is in Chinese. I want to change it to English language but I don't know how? Please help.
As it use Windows Mobile, you need to download english ROM from HTC website. Cnat post the direct link so on google, search for Dopod D810 english language rom and the second link was for download.
Apr 11, 2011 | Dopod D810 Smartphone
Greetings. The dopod 810's below-screen navigation buttons had stopped working so I sprayed them with WD40 (it worked well on the laptop keyboard!). Result: nav buttons show some life but the touchscreen...
you disassemble your device before you spry wd40.. if not you much open your unit because there some lick over the connection of touchscreen connector... you much clean by soft brush...
Mar 24, 2011 | Dopod D810 Smartphone
Dopod 838 Pro Window Mobile 6.5 user manual.
Please download the dopod 838 manual from the below link:
http://www.htc.com/sea/userguide.aspx?p_id=37
Hope this helps.
Regards
Anand
May 02, 2010 | Dopod 838 Smartphone
Pcsuit
Download and install Activesync into your pc. You can download it free at http://www.pocketpc-freeware.net/dopod-d810-device-594/activesync-download-240.html
Mar 29, 2010 | Dopod D810 Smartphone
Transfered memory to a storage card.
you could try a hard reset (It will delete everything like files/contacts etc thought)
Hard Reset
press and hold the left and right soft keys together and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press SEND to restore factory default, press END to exit', if you press SEND Your device will be set back to factory default settings.than Press "OK" to boot...
Mar 19, 2009 | Dopod D810 Smartphone
Where would i get 3D menu software for HTC s710
If its a dopod app your after this may be what your looking for the phone will need to be setup as a dopod or some of the menu items wont work as its not customizable.
the zip is actually the full dopod customization setup so you will need to only install the bits you want
if this isn't what your looking for do a google search as there are quite a few 3d menu apps
Best of luck
Jun 13, 2008 | HTC S710 Smartphone
DOWNLOADING DOPOD PC SUITE
i have dopod d810 but do not have its pc suite to conect to the pc. so pls help me to have that.
Apr 14, 2008 | Computers & Internet
BLUETOOTH! HELP
Go to the start menu, and select Settings. Select Connections from the bottom tabs and find the Bluetooth icon, and click on the bluetooth icon. Select Mode from the bottom tabs and check box that says "turn bluettoth on"
Jan 21, 2008 | Dopod D810 Smartphone
HTC Touch P3450 Smartphone Logo
15 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
