SOURCE: error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit
temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING
ON MACHINE***
You have to reset fuser errors with simulation 14.
Push P * C * then 14 then Start (the button you use to make copies)
and it should reset the code. If not then replace the fuser.
SM
5-1 should turn the lamp on. If lamp blinks on and off it is the
thermistor, if it does not it is the lamp, but check the contacts on
the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective
replace.
SOURCE: add user codes to a sharp mx-4501n mpf
Try exploring the device's web management interface.
Use your wenb browser to connect to the device's IP address.
the default credentials for the unit are
user: admin
pasword: admin
if that does not work, try password: Sharp
(note that the S is capital and the rest are lower case)
