Question about AEG Ovens
I have an AEG B5741-4-M Pyroluxe Oven which doesn't want to turn off. I have to turn it off at the mains supply.
Still seems to cook on all functions and holds temperature as set for cooking. The Heat Bars on thr right of screen stay up on 3 bars.
    Top Expert:
  • AEG Master
  • 60,608 Answers
REPLACE THE SWITCH CONTACTS DO SOMETIMES WELD TOGETHER
Posted on Feb 22, 2019
Amigaman
  • 248 Answers
SOURCE: Oven does not maintain temperature while cooking.
Is this a gas unit? If so you might have a weak oven igniter.
Posted on Nov 24, 2007
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
  • 1462 Answers
SOURCE: AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Posted on Sep 07, 2008
  • 82 Answers
SOURCE: Lengthy preheat time
Hello. I am a Viking factory trained tech. and that is actually a normal preheat time.
Now if it undercooks that is another problem.
You may need your thermostat calibrated or replaced. If you think you are up to calibrating it yourself let me know. If it is the kind that doesn't have any white silicone in the center of the knob stem then it is quit a pain in the neck, but if it does have the silcone then it is a lot easier.
Posted on Dec 03, 2008
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
AEG Oven Heats But Buzzes
lots of them do it. (Including ours unfortunately) in our case this is down to vibration in the casing the fan is screwed to and can be stopped temporarily by pressing something strongly against the top black casing just inside the grill door with the two ventilation slots in it. I wouldn't recommend doing this every time you need to cook obviously. Ours has done it for years it doesn't get any worse. it's not dangerous ( in my unqualified opinion ) and it doesn't affect cooking performance.
Mar 19, 2013 | AEG Ovens
Aeg oven how do you change the bulb?
unscrew the glass. unscrew the bulb
Jan 20, 2013 | AEG Ovens
I have an aeg d2100-4-m oven. main lower oven not getting hot. Have replaced element, to no avail.Fan and light in oven both come on, but have noticed that the temperature dial light is not illuminating....
Hi .
Sounds like the oven thermostat is faulty.,
This gives a supply to the element .
The temp indicator should be lit, if it is not, then I would suggest repl;acing the oven thermostat.
Sep 28, 2011 | AEG D2100-4 Electric Double Oven
AEG competence B4101-4 built-in electric oven, the fan is staying on continually even when not in use. Only goes off if the oven is switched off at the mains. Is there a way to fix this problem?
when i bake a chocolate sponge cake it rises well,when cooking the top becomes cracked like dry earth and when switched off it comes down about a third. with my previous oven baking thesame recipee for 30 years i never had a problem- please advise the reason for this problem
May 26, 2011 | AEG B4101-4 Electric Single Oven
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
Main oven problem
I suspect not the oven element at fault. you only way forward is to actually test the resistance of the element to earth with a megga if you can beg the use of one. be cautious about the result as on occasion, elements are only faulty to earth when hot. another way to test if you are cdarefull, is to connect the element to mains independently of the oven and see if the rcd trips
Sep 22, 2008 | AEG U3100-4 Electric Double Oven
Sep 07, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top AEG Ovens Experts
Steve Allison
Steve Allison
Sal De
Jason Harris
Jason Harris
Are you an AEG Oven Expert? Answer questions, earn points and help others
