NEC DT300 Phone.. no current Voicemail setup - calls just come straight through to the Pharmacists. I dont have any Admin passwords etc either
SOURCE: Keypad not working during phone call
If sounds like DTMF is turned off on your phone. If it is then it is not sending the correct tone over the air which is why nothing happens. Go into setting, then to initial setup and key down toward the bottom and you should see DTMF if it is off change it to short or long and that should correct you problem.
SOURCE: All my Calls go Straight to Voicemail
Here is a link to the user manual for you
http://www142.nortelnetworks.com/bvdoc/norstarbcm/t7316.pdf
SOURCE: calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
SOURCE: number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
