Question about Tablets & eReaders
A zero quad core tablet model number tbqc1065b that was given to me. Won't turn on and not sure if it's charging.
When connected to charger there isn't a indicated light
    Top Expert:
  • Tablets & eR... Master
  • 60,448 Answers
SOMEONE PASSED OFF THEIR JUNK ONTO YOU .
Posted on Feb 22, 2019
tech4222
  • 40 Answers
SOURCE: tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Posted on Nov 18, 2008
  • 102 Answers
SOURCE: Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Mar 11, 2009
SOURCE: re: Battery Charger BC-45W I just
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Posted on Jun 23, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
SOURCE: I have a Vector VECO12C.
I have the same problem and finally found out the internal battery was bad. Having a terrible time trying to locate one
Posted on Sep 05, 2011
My ematic 7 inch quad-core tablet wont turn on or charge
Either your charger is fubar or your batteries can no longer take a charge.
Oct 12, 2016 | Ematic 7" Touch Screen Tablet
I charged my new trio 8x s 4G quad core tabletYesterday, Plugged it in To recharge it Last night And it won't recharge Help me
Interesting - possible that it is not low enough on charge for the charger to operate?
Is the charger working and connected properly to wall outlet?
Sep 25, 2015 | Tablets & eReaders
I charged my tablet and it still said connect the charger . I did that and it turn itself off and won' come back on.
either the charger or the charger cable is bad. battery ran all the way down, and now you cannot turn it on. needs to be charged with a working charger/cable
Aug 25, 2015 | Tablets & eReaders
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
Ematic HD Quad Core will not charge
You have to replace its battery its damaged
Mar 31, 2014 | Tablets & eReaders
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Se tildo mi tablet y no se apaga
What do you mean by branded (that's how google translate put it.) If it will not turn on, I suggest that you make sure it is charged for a number of hours. If it still won't turn on, you should make sure that charger is actually in the socket as well as connected to the tablet.
Sep 06, 2012 | Tablets & eReaders
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Tablets & eReaders Logo
56 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
