SOURCE: Frozen lcd screen
that problem is a factory defect in the if and video section of the tv only the manufacturer could remedy that.take it to a tech so that the video board and the IF board be replaced
SOURCE: AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
