Charger light remains solid green
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
SOURCE: Battery Charger displays green blinking light
This is likely a code from the computer system on the CMM1200 that the batteries no longer hold a charge. If you have a voltmeter, a "quick test" is to put the batteries on the charger for at least 8 hours and then test the DC voltage of the batteries. Test each battery separately by taking the cables off and testing the battery at the positive and negative lead. If they read less than 11.5 volts, you need a new battery set. You can get replacements from www.batteryinternational.com/universal-battery-ub12180-batteries-by-brand-universal-battery-nb.html. The model you have requires two of these batteries. Hope this helps.
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
SOURCE: charger light blinks red never
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
SOURCE: my charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
