SOURCE: error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
SOURCE: I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician.
Here is how I resolved my e3 issue:
1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in"
SOURCE: Dishwasher showing e3 error
E3 error arises due to the malfunction of temp sensor or the heating element. Check for the thermostat.
SOURCE: What is a E3 code on Samsung dishwasher
The E3 error code on Samsung dishwashers is due to the overflow water level being abnormally high inside the machine, this is caused by a blocked pressure system. Start by checking the supply hose for kinks and restrictions.
