SOURCE: I need to remove the engine from my 8hp troybilt horse how do i d
should be 4 mounting bolts
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required.
http://www.briggsandstratton.com/maint_repair/
SOURCE: What year is my wood
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
