Possible procedure for older Toshiba laptop.
https://forums.tomsguide.com/threads/how-to-restore-a-toshiba-back-to-factory-settings.251870/
NO laptop model stated, so there will be not direct answers.!
read the manual yet, at Toshiba, must we read it to you?
here I will tell you the page number to read, is that easy ?
next time post model and we can read it together,
easy as pie.
SOURCE: restore factory settings on toshiba satellite S1800-3545 laptop
You can follow LavaTech's instructions to set the machine to boot from the cd, and you can load any retail version of windows. You will have to go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
to download and install the device drivers.
SOURCE: how to restore my toshiba laptop from factory
To restore your laptop's to Factory Settings, please follow the steps below:
1. Copy all your files and documents to an external storage device.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. choose your country and click OK
6. On the "System Recovery Options Screen" click "Restore Application" which is the last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. "Next"
10. Click "Yes"
11. you will notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish".
Please let me know if it helps you.Thank you.
SOURCE: how do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
SOURCE: How do i restore my toshiba a105 laptop to factory setting.
if you would like to reset to factory default turn off unplug power remove battery wait 30 seconds replace batt & power hold down zero button restart pc do not release zero button until you see screen flashes and you see cursor blinking at top left release follow instructions for restore to out of box state pc will restart several times do not touch until you see choose language page this is for windows 7
SOURCE: restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
