Televison & Video Logo
J
Julia Patterson Posted on Feb 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse tv model sk-26h57od has no sound or picture. Power button comes on
Lawrence Oravetz
Level 3:
  • Westinghouse Master 10,558 Answers
  • Posted on Feb 16, 2019
Lawrence Oravetz
Westinghouse Master
Level 3:
Answers
10558
Questions
Helped
2699958
Points
29284
Sounds like the power supply board might be faulty. Another place to look is the relay that powers the TV either by remote control or the button on the TV
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on May 18, 2009
SOURCE: Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
Anonymous
  • 16 Answers
  • Posted on Mar 23, 2010
SOURCE: TV Turns on picture comes on for 30 seconds then
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Anonymous
  • Posted on May 18, 2010
SOURCE: Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
Having the same problem and wondering if this solution worked :D
Anonymous
  • 117 Answers
  • Posted on Jun 23, 2010
SOURCE: Westinghouse Flat Screen TV will not power on
caps in power supply
jorge888
Its Me Charlie
  • 14 Answers
  • Posted on Aug 12, 2010
SOURCE: my Westinghouse SK-32H540S TV comes
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
1helpful
Westinghouse sk32H540S picture come on then off what's wrong sound good
It's a bad capacitor on the power supply/backlight inverter board. Replace the board and you won't have any more problems.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Westinghouse SK-26H520S no picture sound
The input signal is missing and the blue screen background comes on the screen. Change the input to some other device which you are sure works and see.
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to [email protected]. Please rate my answer if it was helpful, have a great one.
3helpful
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
2helpful
2answers
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
1helpful
When turning, on picture come up for 1/2 sec then goes plank,
My Westinghouse SK-32H240S television fails showing picture. Only sound can we hear but no picture.
2helpful
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
