Cell Phones Logo
A
Anonymous Posted on Feb 16, 2019
When I try pair my device(iphone 6)with my Hyundai i20 bluetooth, instead of saying 'pairing on' like its supposed to it says 'searching' or sometimes says nothing at all
My phone bluetooth is on and ive followed the manual exactly, but this keeps happening. i drive a hyundai i20 2013 model
5 Related Answers
Anonymous
  • Posted on Jul 10, 2008
SOURCE: H500 won't pair with LG Rumor
I figuered it out.........you have to push and hold the BT button down as the phone searches for it. Good to go.
Anonymous
  • Posted on Mar 09, 2009
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: [email protected] Subject: omnitech bluetooth
Anonymous
  • 34 Answers
  • Posted on Mar 10, 2009
SOURCE: I cannot remember how to pair BlueAnt bluetooth to new devices
You will need to set the Z9 into pairing mode before your iPhone will find it.
The manual for the z9 is here
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair.
Joed911
JDTec
  • 4338 Answers
  • Posted on Jan 19, 2011
SOURCE: I have tried to pair my iPhone with my 2007
On iPhone:
1) Go to Settings
2) Go to Reset
3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
On Bluetooth:
Clear all previous pairings.
Once iPhone reboots, turn on Bluetooth.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "Thanks for the help but I guess I have to have a type 2 stereo in order to have the bluetooth and I dont have a type 2"
Anonymous
  • 89 Answers
  • Posted on Feb 04, 2011
SOURCE: Bluetooth keeps aking for a pairing code. each 4
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Testimonial: "worked with an old module i have, but radio is stuck on mute wid dis one. when i insert my newer module,it dos not pair with the phones but BT show up"
I can't pair an iPhone 13 with IHF1000 Bluetooth.
Pressing Search on the iPhone is only half the task. There is a button on the IHF1000 that also needs pressing straight after. After they shake hands, you enter the PIN code. The button often has a the Bluetooth symbol on it.
https://www.fixya.com/support/r26362721-pairing_bluetooth_devices
Even the articles here miss it! It is not the way Bluetooth works, or you could pair to every device around you.
Here it is in the Manual
https://www.manualslib.com/manual/2174663/Motorola-Ihf1000.html?page=18&term=pairing&selected=1#manual
Press and Hold
Press and hold the TALK button to initiate the pairing
process.
https://www.google.com/search?q=motorola+ihf1000+pairing+to+iPhone
I've charge the Z9i bluetooth headset, when I disconnect from wall charger or laptop, it doesn't seem to go on. Actually, nothing happens. I'm trying to pair it up to an iPhone 6. Any ideas why?
There are Reviews here that show you how to use it.
https://www.google.com/search?q=Z9i+bluetooth+headset
I wrote this Tip on pairing Bluetooth Devices
Pairing Bluetooth Devices
Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by ADMIN... on Nov 19, 2016
1helpful
My Samsung 4 will not pair with my halo ear candy Bluetooth
14 TIPS FOR SOLVING BLUETOOTH PAIRING PROBLEMS
Bluetooth depends on both hardware and software to work properly. So if your devices can't speak a common Bluetooth language, they won't be able to connect.
In general, Bluetooth is backwards compatible: Bluetooth devices supporting the Bluetooth 4.2 standard, announced last year, should still be able to pair with devices using, say, the ancient Bluetooth 2.1, launched back in 2007.
The exceptions are gadgets that use a low-energy version called Bluetooth Smart, which works on a different protocol than older, or "Classic" Bluetooth devices. Bluetooth Smart devices are not backward compatible and won't recognize (or pair with) older devices that support Classic Bluetooth. (For example, an old Sony Ericsson phone sporting Bluetooth 3.0 won't be able to connect to a Bluetooth Smart device.)
However, if a device supports Bluetooth 4.0, it can potentially recognize both Bluetooth Smart and Classic. If it does, it's officially labelled Bluetooth Smart Ready.
Gadgets that commonly use Bluetooth Smart include personal health gadgets such as fitness bands or heart-rate monitors. These gadgets will only pair with a smartphone or tablet that also uses Bluetooth Smart - or are Bluetooth Smart Ready.
iPhones running iOS 7 and newer should be Bluetooth Smart Ready as should Android phones running 4.3 or newer, Windows Phone 8.1 devices, and all BlackBerry 10 devices. Ensure your phone is running the latest version of its operating system - but if your device isn't new enough to run relatively current software, you may not be able to pair it with that fitness band.
Devices also come with specific Bluetooth profiles. If Bluetooth is the common language connecting devices, you can think of a profile as a dialect associated with a certain use. For example, you probably aren't going to be able to connect a mouse and a camera because a camera doesn't support the Human Interface Device Profile. But if both a mobile phone and a wireless headset support the Hands-Free Profile, you should be able to pair them.
However, if the pairing failure is a matter of user error, there are steps you can take to get your devices happily communicating with each other.
What you can do about pairing failures 1. Make sure Bluetooth is turned on. You should see the little Bluetooth symbol at the top of your phone's screen. If you don't, go into the settings to enable it.
2. Determine which pairing process your device employs. The process for pairing devices can vary. Sometimes, for example, it involves tapping a code into your phone. Other times, you can just physically touch your phone to the device you want to pair it with. Or in the case of the Bose SoundLink, you only have to hold down a button on the speaker to pair it with a phone.
If you're not sure how to pair a device, refer to its user guide; you can usually find one by searching online.
3. Turn on discoverable mode. Let's say you want to pair your phone with your car's infotainment system so you can enjoy hands-free calling, texting and navigation. First, go into your phone's settings and tap on Bluetooth; doing so makes the phone visible to the car. Then depress the buttons on your car's infotainment system, usually on the steering wheel or center stack, to get it looking for the device.
Once it finds your phone, the car may ask for a numeric code you need to confirm or input on your phone. After you do so, the devices should be paired. Keep in mind your phone or your car may only stay in discoverable mode for a few minutes; if you take too long, you'll need to start over.
4. Make sure the two devices are in close enough proximity to one another. While you wouldn't think someone might try to pair an iPad with a keyboard if the two weren't sitting right next to each other, it's probably worth noting that you should make sure any devices you're trying to pair are within five feet of one other.
5. Power the devices off and back on. A soft reset sometimes can resolve an issue. With phones, an easy way to do this is by going into and out of airplane mode.
6. Power down likely interferers. Say that faithful Bluetooth speaker usually connects to your partner's smartphone instead of yours. If you're having trouble pairing your phone with the speaker, it could be because the speaker is trying to activate its usual connection. Some older devices are very simple. They just try to connect with the last thing they paired with. If a Bluetooth device was previously paired with something else, turn off that other gadget.
7. Charge up both devices you're trying to pair. Some devices have smart power management that may turn off Bluetooth if the battery level is too low. If your phone isn't pairing, make sure it and the device you're trying to pair with have enough juice.
8. Delete a device from a phone and rediscover it. If your phone sees a device but isn't receiving data from it, sometimes it helps to start from scratch. In iOS settings, you can remove a device by tapping on its name and then Forget this Device. In Android settings, tap on a device's name, then Unpair. After removing a device, start at step 1 on this list.
9. Get away from the Wi-Fi router. Another potential obstacle to successful pairing is interference from devices that use the same spectrum, such as your Wi-Fi router. "Wi-Fi has been designed to cope with this, but it might not be a good idea to have your devices directly on top of the router," Powell says.
10. Move away from a USB 3.0 port. "Interference from USB 3.0 is also possible," Powell says. Newer laptops, for example, often have the higher-speed USB 3.0 port, so if the connection isn't happening, try pairing your Bluetooth gadgets away from the computer.
11. Make sure the devices you want to pair are designed to connect with each other. Whether it's a headset, speaker, mouse, keyboard, camera or something else, your device has a specific profile that spells out what it can connect with. If you're not sure, check the user manual.
12. Download a driver. If you're having problems pairing something with your PC, you might be lacking the correct driver. The simplest way to figure this out is to do an online search for the name of the device you're trying to pair along with the word "driver."
13. Update the hardware's firmware. Some automotive audio systems recently wouldn't pair with the iPhone 5, for example, because the Bluetooth drivers in these systems didn't work with Bluetooth 4.0. If you're not sure how to get the latest firmware for your hardware, check with the device manufacturer.
14. Keep in mind that not all wireless devices use Bluetooth. Alternatives include the Wireless Gigabit specification, Wireless HD, ANT+, ZigBee, NFC as well as Wi-Fi Direct. These other technologies typically won't work with your phone, tablet or PC without some kind of additional hardware.
I hope this guide has helped you with your Bluetooth pairing problems.
2answers
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
2answers
Pair bluetooth
How am I supposed to know what headphones or what device you are trying to pair them with?
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
14helpful
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
7helpful
2answers
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
14helpful
Top Hyundai Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Hyundai Cell Phone Expert? Answer questions, earn points and help others
