SOURCE: matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1
speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1
Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
SOURCE: Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
SOURCE: Maytag Elevator Shelf
Let me just say, your post helped me, because I realized that I was not going crazy. But, I was able to find the manual on this frigerator, which was key. There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything. Finally, I realized that there is a triangular shaped part of the rear latch. The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf. The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
SOURCE: Need to hang a shelf to a wall with metal studs?
In order to support any true weight (like books) you will need to use wood blocking between the metal studs. Measure space between the studs, cut blocks to fit and mount at location where brackets will be.
For lighter weight applications, you can use an expansion anchor (but not the cheep little plastic ones that are often provided). A common name for this anchor would be a "molly anchor" and they are available at all hardware stores in a variety of capacities.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=230779-37672-376056&lpage=none
Testimonial: "Thank you ! I gave you a "Very Helpful""
SOURCE: Wire shelf in freezer of Frigidaire refrgerator - how do I move?
since on differnet models it goes right or left,
but you should be able to push the shelf one way, enough so that the other side pops out of the wall
then slide in the long side first, you will see what i mean when you have the shelf out
push the long side in with a lil pressure and raise the shelf the leve you want it installed on
