In a medium bowl, dissolve the sugar in warm water. Soak potatoes in water mixture for 15 minutes. Remove from water, and dry thoroughly on paper towels.
Heat oil in deep-fryer to 375 degrees F (190 degrees C). Add potatoes, and cook until golden, 5 to 6 minutes. drain on paper towels. Season with salt to taste.
It is probably safe. But why not load up one time with new oil and cook a load of french fries, and then throw the oil and fries away, just to make sure.
Change out your hoses and lines to accept vegetable oil. Pro #1, most places have to pay to take away their old vegetable oil. Pro #2, its nice to smell "french fries" driving down the road.
check your hot oil level, it may be above the mark. also follow the maximum recommended batch loading. overloading fryers will result in oil spillage (overflow from tank) during cooking cycle.
It seems to me that if the fries always turn out to soggy what you need to do is to cook them at a higher temperature for a shorter period of time, I think they are sitting in the oil far to long hence the soggy result.
Place the oil tub in the housing, and put the control unit on the back of the housing with the heating element inside the oil tub. Put room temperature (not chilled) shortening and/or lard in the oil tub. (Solid fats make better french fries, IMO.) Put the unit where you aim to cook, on a clear expanse of counter, where no one will knock it off. You are about to make boiling oil, and the potential for injury is truly medieval. Attach the magnetic power cord to the back of the control unit, and position the unit with the front of the control unit, which is at the back of the oil tub, facing you. Plug it into the wall. The magnetic cord attachment is easily knocked off, which is a safety feature, so don't knock it. If it comes off, just put it back on and restart the unit. Push button at lower right of control unit that looks like a 0 and 1 superimposed on each other. This is the power button. Put the lid on the unit with the two slots on top of the lid facing towards the front of the unit where you are. These two slots are where the basket will sit, but you haven't used the basket yet. Adjust the temperture using the + and- buttons. 375 is good for french fries. Now wait until the red light goes out and the green light (I believe) stays on. Now it's up to temperature and you can cook. Put frozen or washed and patted-dry (with a towel) french fried potatoes or battered fish or whatever you want to cook in the wire basket. Quickly lower the basket into the oil and replace the lid: back edge goes down first, then front of lid last. Set the unit's timer if desired, or just use your own timer. It will beep at you when your time is up. When you're done, you can wash the basket by hand or in the dish washer and wipe the unit off with a warm soapy dish cloth. Wait until the oil is cool to room temp before attempting to put the unit in a cupboard. Very hazardous with large potential for mess otherwise!
