Question about Generac 2000 Watt iX2000 Portable Generator
Genarac ix2000 genrator high idle no power - Generac 2000 Watt iX2000 Portable Generator
I have a generac ix2000 and has an overload light on with no AC power out. what do i need to check?
When you have a generator with a inverter in it you have to be careful of overloads an static electricity. More than likely one or more otf the MOSFETs has blown. An inverter is really a switching supply. Not very hard to replace parts but if you have spme skill with electronics take it apart an give it a go. If transistors have not blown you may find a blown fuse inside on circuit board. You will never find a schematic for any of these units. They are protected because the dealers pay to much for selling rights you cant hardly get them. But i would take it apart an see what you have. Or find a good electronics guy an ask him to check it
Jan 22, 2015 | Generac Inverter Ix2000 Gas Portable...
How do I fix this problem
You are drawing to much power and if your not drawing any power and that light is still on then the breakers in the gen are toast
Oct 12, 2014 | Generac iX2000 iX 2000 5793 Portable Power...
Generac ix 2000 how do I adjust fuel mixture
im not suure what you mean about "Bog" but this gen is only good to 1600 watts cont. (2000 peak) and it has a auto throttle so it will idle down all by itself when not loaded past say 40% of total load , but if you think your having fuel starve problems try all the simple things 1st Fuel filer (inside tank) clean carb and stuff like that , I do fix allot of small engines with a good strong dose of stp fuel treatment and i never need to take em apart
May 30, 2014 | Generac Ix2000 Portable Generator Inverter...
Generac troubleshooting
check that the over load switch is not seized of course then replace
Dec 28, 2017 | Electrical Supplies
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
The telivision would not turn on i unpluged it and it turned on for about ten min and tured back off and has not turned back on since
1. may be problem of power supply [smps] it is genrating more than 110v dc
2.your tv's EHT [ Extra High tention Transformer] or line output trasistor is liqui or over heated contact any qualified service person
Mar 12, 2010 | Televison & Video
Generac 2000 Watt iX2000 Portable Generator Logo
75 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
Craig Butler
Craig Butler
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
