SOURCE: I have a Frigidaire stove
your stove is 220 volts,the lights, clock and controls, they work on 110 volts, and when there is a short on the 220 part of the stove, the elements work on 110 volts.that's the reason they only get warm. there is a short in your stove.
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
SOURCE: hot surface indicator light stays on. the knobs
signs of a faulty hotplate sensor especially if the surface is cold
SOURCE: left hot surface light stays on on oven
The thermister might be failing that initiates this indicator. Is the surface hot? you might have to replace the sensor.. it is a thermister which trips a triac to drive the light.
Here
is a tip that I wrote about the problem of the cooktop light staying
on.
Oven
Hot Surface Indicator Light stays on
heatman101
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Here is a tip that I wrote about the problem of the cooktop light staying on.
heatman101
heatman101
