This dishwasher have learning control board check your screen filter bottom middle inside make sure it's clean you need to run unit try self diagnostic mode just consentrate on first error message need to found out what is it fix problem and reset control by running diagnostics mode u should found service paperwork on inside of kuckplate (bottom penal holds by two plastic clips or 1/4 " screws
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
SOURCE: running time of dishwasher
he cycles times are too long
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
See "The cycle doesn't complete" section.
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
Kitchen Aid KUDI02FRSS2 - I have the same problem and called Kitchen Aid (Whirlpool). They originally told me the control panel needed to self-program and that I needed to let it run through one complete cycle before it would lock in the program. When this didn't work they told me the unit has water temperature sensors in it that controls the length of wash depending on the incoming water temperature. When I told them the house water temperature was borderline scalding they said they could send a repair tech out for $75 just to come to the house. I told them to forget it and could buy the control panel for $80 bucks and install it myself for free. I had a previous K/A dishwasher that ran for 30 years without a problem. This one was a problem from day one. Never again - Whirlpool or K/A
SOURCE: KitchenAid KUDP01DLBS2 dishwasher. Runs for a very
Sounds like the heater inside the dishwasher is not working. The machine is trying to get the water up to a preset temperature, probably in the neighborhood of 140 degrees. That is one of the things that it is sensing.
After the machine fills, open it up and take a water temperature reading. After it runs for 10 minutes or so with the water heating light on, but before it drains, open it up again and take another temp reading. If the second temperature is at or below the first temp, the heater is not working. Could be a burned out element, faulty wiring, or bad controller.
Check inside the machine (remove the panel below the door) for a wiring diagram. If there is one there it will give the resistance value for the heater element as well as the wire colors, the circuit diagram, and the cycle times.
SOURCE: Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
