Question about Hitachi Magic Wand Hv250r Hand Held Massager
When i plugged in my magic wand all the buttons are flashing and it won't turn on. How do I fix this?
When I scan something with my magic instascan I can not find it on my computer. Doi need to install something first?
Make sure your wand is turned on. You have a microSD card inserted in the Magic Wand. Go to "My Computer" and look for a removable disk drive.
Oct 05, 2013 | VuPoint Magic Instascan Hard Case For...
I have a saeco magic comfort coffee machine and the display is showing " ventilate" . I have looked in the manual that comes with the machine and there is nothing about ventilate. can you tell me...
That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a solenoid for the water. That would have to be fixed by a service unless you are very handy.
Feb 11, 2011 | Saeco Magic Comfort Plus Espresso Machine
Have purchased a Harry potter voice-activated wand torch. However there are no instructions showing how to program it! Please advise.
press button on back of wand once, wand tip will flash, then red light will activate speak clearly and say lumos, wand tip will flash again to say recording finished to deactivate press back button twice and again say clearly nox . it is now programmed to play just tap wand and say lumos to switch on and tap and say nox to turn off, once programmed no need to press back button. or go to tomy web site put in harry potter wand torch when product info comes up, there is manuel button click onto it and full instructions will open in a new window for you to save.
Oct 10, 2010 | Tomy Toys
Fix my sony BDP-S550 to be region free
Full procedure for a basic one-for-all remote this is the only way that this DVD player can be set to region free. You can also buy one ready programmed but this is too easy with the remote.
1. Press DVD
2. Hold the magic/set button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic/set button until it flashes twice.
5. Press 994
6. Press Magic/Set Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic/set button until it flashes twice.
10. Press 994
11. Press Magic/Set Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic/set button until it flashes twice.
15. Press 994
16. Press Magic/Set Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic/set button until it flashes twice.
20. Press 994
21. Press Magic/Set Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic/set button until it flashes twice.
25. Press 994
26. Press Magic/Set Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S550 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it. It should read "HOME" on the front panel.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The blue 24p light will start flashing on the front panel
3. Put the player back into standby with the Sony remote
4. Next time you turn on the player it will be region free for DVD playback
Dec 11, 2009 | Sony BDP-S550 Blu-Ray Player
Can the Magic Wand Rechargeable Massager be charged from a 220 volt power?
If your wand is N American then "don't do it" 220 through a 110/120 will fry all the magic out of it. You could get a step down transformer 220 to 110. Plug that into the 220 socket and plug your magic wand charger into that.
The cost would not be worth it though ... buy some more magic that is 220. be happy ... not sorry :-)
Nov 17, 2009 | Hitachi Rechargeable Wireless Magic Wand...
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic squirts water out the wand when brewing
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Apr 11, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Water light is flashing but tank is full
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Hitachi Magic Wand Hv250r Hand Held Massager Logo
32 people viewed this question
Top Hitachi Health & Beauty Experts
ray gallant
Bill Boyd
Are you a Hitachi Health and Beauty Expert? Answer questions, earn points and help others
