L
Lee Vogel Posted on Feb 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung 2525W laser gives error message "cover is open"
Adorjani Laszlo
Level 3:
  • Samsung Master 1,316 Answers
  • Posted on Mar 31, 2019
Adorjani Laszlo
Samsung Master
Level 3:
Answers
1316
Questions
Helped
457111
Points
2563
Change the microswitch afferent the cover is open.
5 Related Answers
A
Anonymous
  • Posted on Jul 09, 2008
SOURCE: Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Anonymous
  • Posted on Jan 31, 2009
SOURCE: error message inner cover is open canon pixma mp610 printer
Had the same problem myself but discovered that I had previously moved the inside flap down when I put the ink in. I moved this back into position and bingo! (If you make sure all the covers are closed then look into the printer where the paper exits you will see the flap that moves up and down, this must be in the up position)
Anonymous
  • 105 Answers
  • Posted on Nov 20, 2009
SOURCE: Our HP Color Laser Jet 4700 dn frequently gives an
There is either a small piece of paper in your paper input section or you have a paper sensor going bad.
Anonymous
  • 1216 Answers
  • Posted on Feb 07, 2010
SOURCE: my laser printer gives message open heat error
This is most commonly caused by a failure of the Fuser unit.
However, in rare circumstances, this can be caused by the Fuser Control section of the SMPS, or the fuser temperature monitoring circuit on the Main Board.
There is a closed control loop:
1. AC voltage is supplied to the Heat Lamp in the Fuser from the Fuser Control section of the SMPS
2. The temperature of the fuser heat is monitored by a thermistor (mounted on the Fuser) connected to the Main Board.
3. The Main Board determines if the fuser temp is too low, correct, or too high and signals the Fuser Control to increase, maintain, or decrease the AC voltage to the Fuser
sorry io say but you had to replace the fuser
call dell costumer support and tell your model no. ask for fuser replacement and they will do it .
Hope your printer is in guarantee period otherwise you had to pay.
REGUARDS
Anonymous
  • Posted on Apr 30, 2010
SOURCE: Samsung ML-2525W monochrome laser printer;
I have the same problem with mine - first job usually prints but no go on the second one. It tells me the printer is "offline". In some cases I can't even power cycle normally. I have to unplug the back cord and plug it back in, then I can power back on.
I called Samsung today 1-800-726-7864 and was told the printer will need to be taken to a repair center for service. Wish I had better news.
How do you do a factory reset on a Samsung ml-2525w printer?
If you have the install disc for the printer , you could delete from the hard drive and reinstall, If the Data is not installed in the printers memory this should work.
How to clean ML-2525W Mono Laser Printer ?
did you try a different toner cart if you did and it still does this it is your laser unit. try the cartridge first if it still does it then take it to your local samsung dealer.
My printer is giving message that you rear cover is open for that what to do?
SAMSUNG SCX 4521 PRINTER BACK SIDE COVER IS OPPEN SO PLEASE CLOSE THE BACK REAR COVER & CHECK THE PAPPER JAM IN REAR COVER & AFTER CLOSE THE REARE COVER THEN AFTER SEE THE ERROR YOU CHECK THE BACK COVER SENCER & SENCER PCB
9helpful
Won't scan, error message -scanner door is open
Simple solution. I just had the same problem. Make sure the top cover on the left side is snapped in. It wasn't obvious that it was open. They should probably give a better code because it is not the scanner door that is open.
3helpful
2answers
Samsung ML-2525W monochrome laser printer; connected via USB to MacBook Pro. Prt driver 1.00.02. First job prints fine; 2nd job in queue fails to print, and ''Open Print Queue'' indicates ''printer...
Samsung CLP-300 - Cover Open error message, but covers are closed
Front cover is on the right hand side, back is on the left hand side in the middle, and the top cover is like a little button on top. All the others are little openings.
3helpful
3answers
Error Message
"Open heat error" ---
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Good Luck!!!
neo
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
