Sounds like the keyboard might not be detected. Double check the interconnect cable connector. That will then get you into bios to check time and date settings.
BIOS must work, and is first.
so did you use the BIOS hot keys first.
and set time and date
or is the RTC coin cell dead, as all are this old.
what does switched screen mean,,,????
2007, 12 years old today, and RTC battery goes bad 5-7years
so how can that battery be good now? this old.
we change it first, if the volts reads below 2.9v its bad or doing so FAST.
once this works the BIOS then works and the RTC clock works.
ok?
page 28 pdf.
F10 is the bios pages entry page, prompted on the screen for 12 long years, now is the time to do that.
see bios page1.
F1 is info page
Esc is main bios settings bingo set the clock. (and date)
The first thing to do with old PCs like this is kick that 12 year old huge battery to the curb
the replace RTC coin cell
the see BIOS work on AC power only or even forever
then reset BIOS defaults page 29
and last get hdd to boot now.
in that order.
https://www.manualslib.com/manual/273152/Hp-Compaq-Nw8240.html?term=setup&selected=2&page=28#manual
Switch ON , after switching ON
Press ctrl+Alt+Delete
At right hand side lower portion you will found Shut down, click option appear then click Shift + Restart
Chose options to reset.
That's it.
the time not set means the RTC coin cell is dead, as all are 12 years old. (age matters)
RTC is the real time clock chip in side
and stores time in the RTC NVRAM
and is held by coin cell battery power from not forgetting time and data.
I worked at intel for 6 years as tech so....
SOURCE: HP nc8230 no BIOS setup and system time error
the simple thing is that are the both system compartible?so if they are not just compartible go to the local pc outlet in your area and get a compartible one better you go with the faulty screen so it could be easily verify.
SOURCE: i have a notebook hp
You need to get a Windows 98, Windows ME, or Windows XP boot disk and boot your laptop. Ignore all messages and once at dos prompt, type the word "TIME" and set the time and hit enter. Then type the word "DATE" and then set the date. (You do not need to type the commands in capital letters)
