Question about Triumph Office Equipment & Supplies
Afternoon, pls I need a help. Call service c6000 on triumph Adler photocopy
  • Triumph Master
  • 8,890 Answers
  • 40 Answers
SOURCE: Triumph-Adler 4035 Firmware
latest firmware for FS-3900DN:
system: 2F9_3000010.004 checksum:5204 version:010.004
engine: S2F9_1000011001 checksum:f7bf version: 011.001
I don't think the problem is in the firmware ...
Posted on Jan 10, 2009
  • 126 Answers
SOURCE: error C6000
This is a fuser problem. Try this to reset:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Posted on Jan 16, 2009
SOURCE: error code
E0064-001
Posted on Feb 05, 2009
muntejaya
  • 10421 Answers
SOURCE: Hi , I am using cups
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__jy764e
Posted on Feb 26, 2011
SOURCE: how do you set the tax functio on a T 1210
step 1: Turn the calculator on
step 2: type in the tax percentage; the digits
step 3: push <TAX SHIFT>
step 4: push <+TAX>
step 5: just see the display blinking "RATE TAX %" while showing your input rate
step 6: when blinking has stopped, push <CE>
Now you're done.
You can check by entering the number "100" and then push <+TAX> to see the inclusive amount and then pus <-TAX> to see the exclusive amount again.
HTH
Posted on Mar 06, 2011
Pls show me how to reset Triumph-Adler DC2018 error code c6400
Thanks alot. It really worked for me, i mean the reseting procedure of menu>service sett>press #+start button+enter same time>enter 163>enter>go down to Execute>click start button. Then Restart machine. Wait a little so it adds toner then say 'ready to copy'. Hope somebody finds it helpful too
Apr 17, 2018 | Office Equipment & Supplies
How to resolve the problem c6000 Photocopier name Kyocera multifunctional km1650
I have provided a troubleshoot guide. Hopefully that will help you.
http://www.scribd.com/mobile/doc/60850340/Kyocera-Service-Error-Codes-Summary
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 04, 2016 | Kyocera Office Equipment & Supplies
Triumph Adler error C6000
Replacing the fuser will fix that. Or if you want to strip it down check the lamps and if they're OK change the thermistor and thermostat. But your better off just replacing the whole uni
Apr 19, 2015 | Office Equipment & Supplies
Triumph -Adler Dc 2020 with Error code c 710 please help?
Toner sensor problem or Developer problem Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Feb 25, 2015 | Office Equipment & Supplies
Triumph-adler DC 2018 error C6000
Defective Fixing Unit... Poor contact in the thermistor connector terminals, bad thermistor, broken heater lamp wire or some other contact problem related to fixing section. If it is possible, check with another Fixing Unit.
May 02, 2014 | Kyocera FS-3900DN Laser Printer
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Jan 20, 2013 | Kyocera Copystar CS-1635 Copier
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
How do you set the tax functio on a T 1210 calculator by Triumph Adler
step 4: push <+TAX>
Now you're done.
HTH
Dec 20, 2010 | Adler Royal T-1210 Basic Calculator
May 02, 2008 | Kyocera FS-3900DN Laser Printer
20 people viewed this question
Top Triumph Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Triumph Office Equipment and Supply Expert? Answer questions, earn points and help others
