SOURCE: Freezer cool, but Frig section is not cool
Volman, take a look in the freezer section and see if you have a heavy build-up of frost on the back panel. You want to take the evap cover off and see if the evaporator is frozen up. If so, your refer did not go into defrost and cannot move the air over to the refer side. If this is the case you will have to defrost that evaporator completely. On these Amanas the culprit is usually the bi-metal which sits on the evaporator. Look at it and see if it's buldged. The part number for the bi-metal is ro131661. If you defrost the evap your refer will start cooling again normally until it freezes over again. This will give you time to replace the bimetal....Catriver...post back.
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
SOURCE: fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
SOURCE: Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
SOURCE: 2001 Ford Taurus blowing hot air from the vents
I have the same problem on my 2000 Taurus. I've been told by a Ford service technician that it is probably an intermittent problem where the blend door gets stuck in the 'heat' position. I have electronic A/C controls, and there is a diagnostic procedure I can do where it runs the blend door through its full range of motion, and which seems to get it unstuck. If the problem happens again (and as I said, mine is intermittent), you might try doing the same thing by turning the dial all the way from hot to cold and back again a few times, to see if it gets unstuck. Or you could try to repair/replace the blend door.
