Question about Casio Music
Hi, I have a Casio Celviano AP-5 piano, my dogs broken the plug connector of pedal, are 7 slim wires of color, I don't know the order of it. Can someone help me? Please! I need repair my piano,
c
  • Oscar David Virgez Castro
    Is an old piano, and in my Country no have a proffessional to repair!
    Problem Solver:
  • 6 Answers
I think it's better to apply to the professionals, to save both time and money
Posted on Feb 15, 2019
  • 5603 Answers
SOURCE: I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
Posted on Oct 06, 2009
  • 5603 Answers
SOURCE: I have a casio wk-200 piano. I bought headphones
The keyboard has a mic jack that is the same size as the headphones. You probably put the headphone plug into the wrong jack is all.
Posted on Jan 10, 2010
  • 4 Answers
SOURCE: When I plug the pedal in and play, the music is
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Posted on Feb 28, 2011
SOURCE: Our Casio Celviano AP-620 won't
My AP-620 has a pedal problem too... it sticks and I keep hearing the music I play ring out after the pedal is relaesed
Posted on Mar 08, 2011
  • 5603 Answers
SOURCE: Hi, I hope can help me with this problem because
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Posted on Jun 08, 2011
Testimonial: "fredy2 is simply a "wizard". A patient, reactive and efficient one: only 2 tries, and my gear has been fixed! When no one could help me, he did. thx!!"
Yamaha Clavinova Piano CLP-122S pedals connector
This should help you trace the wires
May 05, 2018 | Yamaha Music
Connecting to garageband
Only newer models with class-compliant USB (made last 12 months) can connect to MACs - & IPADs and PCs.
Older models require drivers available only for Windows.
Mar 13, 2014 | Casio Celviano AP-220 Digital Piano...
Casio piano seems to be frozen
It is 3 years/5 years warranty depending on your country.
Call CASIO warranty or contact dealer.
Feb 16, 2014 | Casio Celviano Ap420 Ap-420 Home Digital...
My Casio AP 620 Celviano says "Loading" soon as I switch it on but is not working
Could possibly power supply problem. If you're running through a multi-board, try running directly into the outlet. Failing that, try another power outlet altogether.
The Celviano range aren't real power hoggers once going, but initialising and starting up takes a bit of omph.
Sep 09, 2013 | Casio AP-620 Celviano Digital Piano
I have a Casio CDP 200R. I recently purchased a FC4 foot pedal but it works in the reverse way. I tried switching the piano off and then plugging it in and it still does not work. Can you please let me...
You should try having the pedal connected when you turn unit on. Some pedals can be rewired to act opposite... However I believe this pedal should work with the Casio. You can open the pedal and see if you can move one wire so it works opposite. Also verify that the jack is set to the "SUS" setting per your user manual... around page E14
Sep 07, 2011 | Yamaha FC4 Piano Style Sustain Pedal
Ok i was playnig on my celviano ap-620 and then 8 of the keys started to sound rare, very loud, it seems like it lost the key touch sensivility on those keys from the center (C) and 8 keys down i tried...
What has happened is that one signal wire of the matrix that scans the keyboard has opened up. Each key has two contacts. One closes before the other and that is how they measure key velocity to control the loudness for piano sounds for example. When one contact doesn't work, often the sound is set to MAXIMUM key velocity resulting in MAX loudness. The key contacts are scanned digitally in groups of usually 8 or 12 and, for instance, every C key has a single line attached and then every group of 8 or 12 has a second line and then there are two complete sets of these to implement the velocity sensing. Your unit probably has either a break in a cable or possibly a cable connector that has failed or not seated OR worst case, the circuit board under the keys has a crack breaking one wire or circuit trace going to that section of the keys. The problem will require opening the keyboard to repair. If you are not electronically adept, besst to take this to a repair shop.
Aug 14, 2011 | Casio AP-620 AP620 Digital Cabinet Piano...
Music Logo
Top Casio Music Experts
Ben Armstrong
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
