SOURCE: rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
SOURCE: Cannot unscrew cap on rinse aid compartment in door of Whirlpool Gold Quiet Partner III
the cap doesn't come off, you just have to open the door all the way. then, when you pour the rinse aid into the dial area, it will get sucked into the dispenser. but if the door isn't open all the way it won't go anywhere and will overflow on you.
SOURCE: THE RINSE AID CAP MELTED
If the model number you posted this question under is correct, the part number for a replacement Rinse Aid Cap is 8564929.
You can purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If the model number is not correct, please post back with your correct information, or use your model number at the sites I provided, for your search criteria. I hope you find this informaiton helpful.
Testimonial: "Thank you for your timely expert advice! I appreciate it! -VLS"
Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
