Question about Nikon Cameras
Nikon D100 can read CF card but when I take a photo (without lens) it won't write to the card. Why is that?
I'm getting a lens too and I suspect the cards might be old so I can buy a new one, it's just a very odd problem that I can't find an answer to.
  • Nikon Master
  • 18,002 Answers
Did you format the card in that camera? Is there a lock switch on the card?
Posted on Feb 15, 2019
Testimonial: "i formated the card through the camera and there is not lock switch on the cards that i have and I dont have the lock switch on my camera on either"
  • Brad Brown Feb 16, 2019
    That camera might need a CF card and not an SD card
informatica
  • 1114 Answers
SOURCE: "card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 02, 2007
Nick Spirov
  • 35 Answers
SOURCE: Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Posted on Jan 16, 2008
  • 8 Answers
SOURCE: CF Card
Please post back the error message you notice.
Posted on Mar 28, 2008
ginko
  • 19396 Answers
SOURCE: Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Posted on Feb 13, 2009
  • 3 Answers
SOURCE: NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Posted on Mar 30, 2009
Card pin bent - Nikon D100
Take a look inside your camera's CF card slot. It's very likely that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jan 16, 2012 | Nikon D100 Digital Camera
Do the Nikon D100 and the D70 share the same in camera Compact Flash unit - not cards - but the hardware to accept and read the CF card? I have a bent pin in the D70 and want to know if I can change out...
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
Oct 02, 2009 | Nikon D100 Digital Camera
Mar 21, 2009 | Nikon D100 Digital Camera
Nikon D100 shows # of pictrues left - on the display -
This is normal. Page 17 of the D100 manual says when the main battery is inserted the display will show the number of exposures remaining. If no CF card is inserted it will show E.
Nov 25, 2008 | Nikon D100 Digital Camera
Nikon d100 cf card not recognized
yes i know about this problem. basically its your sensor reading chip which has burnt out. it can be replaced at a cost of about £40/ so not expensive.
hobble@iol.ie
bye
Oct 05, 2008 | Nikon D100 Digital Camera
My D100 will not accept CF cards
You can always try the reset button. It is under the flap where the USB/Video out/ and power connector is. It is just above the power connector.
Oct 01, 2008 | Nikon D100 Digital Camera
R06
r06 is the buffer count for the camera. read here: D100
you must have another problem if it will not fire. Have you tried a different lens or memory card?
Apr 09, 2008 | Nikon D100 Digital Camera
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
Nikon d100 issue....
make sure you have card inside, your lens if fixed correctly and your lens aperture by the end max 32 or 22
Dec 01, 2007 | Nikon D100 Digital Camera
Cameras Logo
44 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
