Invacare Panther MX4
hi check you're battery's with a load tester
available on E/Bay approx cost $35 .this will give an accurate reading on there condition...cheers
Buy Xarelto 20mg Online Tablet is used in the treatment and prevention of deep vein thrombosis and pulmonary embolism. It's manufactured by Bayer India. Xarelto 20 mg price, uses, side effects, Dosage. Cheap Xarelto 20mg. Order Now.
SOURCE: My wife has an Invacare Buzz scooter - I have got
The Buzz breaks down into four pieces for transport. Electrical connections must be unclipped to separate it completely. It is possible that one of the connections isn't completely clipped together, so my first check (after you have made sure that you have it plugged into a working outlet!), would be to take it apart and then reconnect everything firmly. While you are at it, you should look for any other clip-connections and undo, then redo all of them. Even those that "look okay". Inspect the connections metal fittings for signs of corrosion or dirt that may be causing a high-resistance connection, and clean as necessary. Run you fingers along the wiring to check for any places that my have been damaged, breaking a wire connetion in mid-stream. Make sure the connections to the batteries are clean and free of any corrosion too. Be sure to check the fuses to make sure you haven't blown one, and also push in your circuit breaker. These sometimes trip while charging due to spikes caused by thunderstorms. If you do all this and it still isn't charging, you'll need to open the shroud at the head of the tiller and inspect the connections running up inside the tiller, and the connections going to the PC board located at the very top of the shroud where the thmb-paddles hook into the electrical system. There should be a fuse inside there too, so check that.
Good luck.
SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
SOURCE: Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
possibly connected the wires to the switch back up wrong
