SOURCE: runs back in cold weather
The most likely problem with your van, assuming that there is no check engine light being lit is that the small motor on the air intake manifold has stopped working . this will cause the motor to run badly when it is at idle forcing you to keep the gas pedal depressed to keep it running smoothly. This motor usually has only 2 screws securing it to the manifold so it is an easy fix.
Rich Lilja
SOURCE: I have an Equity Weather
The wireless unit that transmits to the indoor unit is weather resistant, but not immersible. Even so, try to shield the transmitter from the sun and rain, if possible. When positioning the transmitter, keep in mind that direct sunlight may cause false readings and mounting it on heat-retaining materials (like brick) will show a higher temperature, even after sunset. Avoid mounting it anywhere near things that give off heat (air conditioner units, dark exterior walls, etc.).
LaCrosse has not yet uploaded the manual for this, but you may check later at:
equitybylacrosse.com/31215
Good luck from Detroit, MI.
Testimonial: "Thanks the information given was very helpful"
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
SOURCE: Lacrosse weather station model T85647
Either the sensor is defective or the receiver is, toss a coin.
