SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
SOURCE: hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
SOURCE: Saeco Incarto No Power problem
Check the capacitor which is under the pump and behind the power switch.
SOURCE: Total dead, no power? Changed fuse in plug and
This is quite an easy problem to fix. Whats happened is the water heater has overheated and tripped the power as a safety measure.
Take off the Left hand cover, there are 4 torx screws. You will see the water heater. with what looks like 2 circular teminals held on the side with a metal strap.
these are one shot thermal cut outs. the same as on a tumble drier.
Tassimos are over engineered and really only need one thermal cut of. if there are no lights on the front, the brown wire has tripped. if there is light and no heat the blue wire has tripped.
What I did was swap the brown wires over to the trip that had the blue wires on, so you still have a thermal trip. and bridge the blue wires together and taped them up - voila it works again. DO NOT CROSS THE BROWN WITH THE BLUE> BOOM!
to do the job properly take off the thermal trips and go to an applicance repair shop. of they dont have them on the shelf i would suspect they can get them they are very generic. try not to lose too much of the white thermal paste as this helps with the cut off. if you do lose some its the same as used on CPU heatink compound. put them in and replace the strap and re assemble.
FIXED
SOURCE: Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
