Question about Toys
It go reverse good but go forward stuck in an inch
I have a Brother sewing machine,model XL 6562, unsure of age, it's older. Today it only sews in reverse, cannot make it go forward. Help!!
well reverse button must be stuck. Try turning wheel to move forward and setting the stitch, like to zigzag. Oil it good, old machines get "thirsty".
Aug 01, 2017 | Brother Sewing Machines
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Singer Quantum CXL: After I use the reverse button and release it, the machine does not go back to stitching forward. It stays "stuck" in reverse until I turn it off and back on again. :-( ?
the reverse mechanism is not releasing to go back to its normal forward position. if you do not have pressure on the reverse button and it feels like there is some slack with no tension on the button, the mechanism has not returned to the forward position. there may be a spring that has the end broken off to keep tension on the reverse mechanism,, it would be a good idea to have the machine checked to see what the problem is.
Jun 02, 2015 | Sewing Machines
The shredder only goes in reverse. I did oil it, but it doesn't work.
did you try to fix the forward problem by oiling it? That would be my first choice. The Forward and reverse switch would be my first thing to check to make sure the switch is working. Next would be the actual motor to see if it's getting power to go forward.
Oiling it won't fix the forward problem unless it was somehow stuck which would be unlikely since it goes in reverse.
Sorry I couldn't give you more help with this.
Good luck.
Mar 11, 2015 | Shredder Office Equipment & Supplies
Not moving forward
the blades and the drive use different belts take a look at the drive belt
Apr 07, 2012 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Have b&d firestorm 14.5 volt cordless, forward and reverse switch broken older model but hate to throw it away. it is stuck in forward andhave two batteries and good charger throw away? or fix ?
Fix! We had the same problem, and when we opened up the case (8 screws and a pin later), we found that a tiny plastic tab had broken off the Forward/Reverse selector, which costs less than a dollar. We ordered it from a local supplier to avoid $10 shipping.
Aug 30, 2011 | Black & Decker & Cordless Drill
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
The trans. stays reverse no matter what gear you put it in
It may be a shift fork or a synchronizer stuck Try running it around alittle in reverse and see if iy helps. good luck
Mar 27, 2009 | kawasaki W 400 Motorcycles
Both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Mar 24, 2009 | Garden
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Toys Logo
51 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
