I have a 24 inch Vizio E241-A1 TV I press the power button it will not turn on I check the wires and all the outlets still nothing I already open up the back of the TV I don't see anything wrong with the power supply or circuit board
SOURCE: Toshiba TV model CZ27V51 - picture+audio off, red light flashing
hi there, Flashing light red means a shorted electronic component is need to be replaced. do some test at video section, most of it are diode, transistors, transformers. ty
SOURCE: RCA 52 INCH D52W20B WON'T COME ON
Just fixed it!!! Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
SOURCE: 42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
SOURCE: My vizio e371vl will not power on but the orange vizio stays on
We had the same issue and replaced thr batteries then both power buttons started working. Never would have guessed that even the power button on the TV would not work if the batteries in the remote were dead. Problem fixed!
