SOURCE: Date Code Information on ExcelStor Callisto 80GB drive label
yeah u can find on top sticker of hd.
SOURCE: i have a ryobi lawn mower with a 6.5 hp motor. it
I am working on one now. Customer said "it doesn't run". Ok. So, after oil/spark plug/air filter replacement...it didn't have any gas getting to the carb. Took off the bowl, and on this 2005 lawnmower, the inside of ALL of the carb was covered with a white/chalky film. Looked like tiny rust barnacles over ANY metal surface available. Silty white stuff in bowl. Blasted it all w/carb cleaner. Still couldn't get primer to work, but after I sprayed a bit o' starter in the cylinder, it started well & kept running. Until I let the bar down. Needs a new carb. Will see what the customer wants.
SOURCE: What parts do i use for ryobi riding lawn mower
MTD is a manufacturer of lawn and garden equipment.
As for parts, contact your dealer for whatever parts that you may need. If you have a parts diagram for your rider, you can search for the part numbers on the internet as well.
most small batteries only last a couple years
