SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
SOURCE: I can't drop feed dog on my Husqvarna viking 230
It sounds like maybe you have it set up to make button holes.
SOURCE: How do I lower the
It's been a while since I have owned a series 2000 Husqvarna, but from memory there is a little white (?) button on the lower right-hand side - near the knob for stitch width - it has a notch on the underside. Push the button in, push it in a downward motion and the notch should catch on the edge of the hole and stay there (in other words the notch "disappears" inside the hole). The feed dogs will be lowered. To raise them, push in the button again and let it lift up and then outwards (you see the notch again). Turn the handwheel once and the feed dogs pop up.
SOURCE: dog feed with husqvarna viking
You should join the yahoo group "vikingsewingmachinespre1980". Bill will take very good care of you. I'm new to that group and have gotten every question I've asked answered. This is just for pre-1980 Vikings which includes the 6000 series - including the 6440. Good luck.
