Hello friends, I have a trimmer machine Philips Series 5000 and I got burgled andmy charger was stolen by the thieves leaving the machine :) So I took a new charger, because it's a very good machine. Anyway, I have a problem with my new charger. Normally the machine needs to be charged for an hour, but this charger cuts off after 3-5 minutes and doesnt charge more. What would be the reason ? I have no way to return or guarantee the charger. While I was looking for a new charger, I read this on machine, USE ONLY WITH PHILIPS HQ8505, then I bought it. So I got the right one. But it still doesn't charge properly. I would be very happy if there was a friend who could help. Thank you now.
It sounds like the charger is defective or the wrong one. There are two chargers that will physically fit your shaver but only one will work. The correct one can be found at shaveroutlet.com
https://shaveroutlet.com/norelco-philips-shaver-wall-charger-transformer-cord-p-270.html
SOURCE: Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
SOURCE: LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
SOURCE: I have a Philishave bought
Based on the information you provided, it sounds like it is a Quadra Series shaver but it is not possible to tell the specific model number. The model number should be written on the shaver somewhere.
shaveroutlet.com has a video that can help you find the model number. See link below
http://shaveroutlet.com/video_tutorials
Testimonial: "Thank you very much brector3, The video helped. It was on the back in tiny writing."
SOURCE: Philips norelco G370 charger Not
Dear Mr Selvaraj,
We regret the inconvenience faced.
We would request you to share your contact details with us in order to get this issue resolved for you.
Thanks for your patience.
Regards
Philips Consumer Care
1800 102 2929
1860 180 1111
