SOURCE: nintendo wii
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right after started to fall in place perfectly, just try what password type will work for you...my wii started connecting to my router and never had the same error code ever since.
SOURCE: Wii Error Code 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router lookup page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Also make shure the wii is not to far from the roughter.
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
SOURCE: error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
